Please help to solve the issue that I want to make a text box editable on button click but the textbox read-only property is not bindable property so facing issue to make it editable?
Although not as nice, you can use visible/invisible with two boxes
or embedded mashup and mashup parameters
Hi @yasmalik.
If the previous response allowed your to resolve your issue, please mark it as the Accepted Solution for the benefit of others on the community. If you have found a different solution, we would be happy for you to post it here and mark that post as the Accepted Solution.
Thank you for participating in our community!
--Sharon
