I'd like to have an Alert tied to a Property of a Thing that when the Property changes the Alert will trigger an Event on the Thing. I need to bind this Event in a Mashup to trigger another widget's event.
Any pointers? Examples and screenshots VERY welcome!
Hi Chris
On Thingworx 7.2.5 or higher, In Mashup builder there is a service property on GetProperties called “Automatically update values when able.” A possible workaround may be to add a property to a thing so that whenever this property changes,bind the event to the "ServiceInvokedCompleted" whatever event you want to fire and automatically t the mashup will update.
Hi Chris
Hi Christopher,
I agree with armando. Please check this link for more info on your requirement: http://support.ptc.com/help/thingworx_hc/thingworx_7_hc/#page/ThingWorx_Core_Help_Center%2FThingWorxHelpCenterDITAFiles%2FMashupBuilder%2FMashups%2FMashupAutoUpdate.html
I hope it helps.
Ankit Gupta
