For my project, I want to add multiple plots in the Google Map. I have read somewhere to add infotable in the service. But what code I can use it there ?
Please help me
If your things have a location property, in a mashup, you can add a service which returns the list of things with their data, for example, GetImplementingThingsWithData. You can bind the result AllData of this service to Data of the GoogleMap widget. In the Location property of the GoogleMap, you chose the Thing's property which is the location. So, all the location will be marked on the map.
Similar posts:
Hello ,
Please follow the code for Multiple marker in Map.
In your service add result filed as Info table and add filed you require.
var params = {
infoTableName : "InfoTable",
dataShapeName : "Datashape"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(Datashape)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
// location:LOCATION
var location = new Object();
location.latitude = 42.452;
location.longitude = -72.124;
location.elevation = 0;
location.units = "WGS84";
result.AddRow({location:location}) // You can Add multiple marker using Add row.
Thanks ,
Mayank
