How to measure test Coverage
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
We are writing automated integration tests to our platform. We are using Selenium and NUnit to write the test code in C#.
Our problem now would be on measuring our test coverage :
We write our methods in Javascript, and we know that they are all available as REST API, but as we are interest in doing code coverage, to do this we would have to instrument the generated mashups javascript files.
Is there a way that we could do this? How could we access these files?
Did someone already tried test coverage on ThingWorx platform?
Thanks.
- Labels:
Connectivity
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Radix, if understand you right you are looking for the code behind the Mashups that are created within the Mashup Builder, I think the only check you can perform is on the entity's metadata which is defined in XML format. I'm not aware if you can actually get access to the code itself
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Thank you for your answer.
Do you have any idea how we could measure test coverage on ThingWorx?
If we can't access the code, it would be really difficult.
