How to migrate from ThingWorx cloud version to on premise version?
SD_10134497
I am currently using the Thing Worx Cloud version and need guidance on how to migrate or switch to the on-premises version. Could you please provide:
1. The necessary steps or documentation for this migration?
2. Any prerequisites or system requirements for the on-premises setup?
3. Information on licensing or additional configurations needed during this process?
slangley
(To:SD_10134497)
Hi @SD_10134497
If you are actually considering migration from PTC hosted to on-premise, this will require contractual changes, and you will need to work with the Sales team.
Please be advised, however, that if you simply need an on-premise instance for testing and development, your contract already allows for this.  You can then use Solution Central for migration of projects to the hosted production instance.
For setting up an on-premise instance, refer to the Help Centers for the relevant version for validating System Requirements and Installation Instructions.
If you have further questions, please don't hesitate to ask.
Regards.
--Sharon
Hello @SD_10134497 ,
Hope you are doing well!
I assume if you are using PTC cloud ThingWorx instance, and planning to migrate to on-premise version. Kindly connect with your assigned CSM for the knowledge of complete procedure.
Thank You
Bhawna
slangley
(To:SD_10134497)
Hi @SD_10134497
Regards.
--Sharon
Hello @SD_10134497
It looks like you have some responses from some community members. If any of these replies helped you solve your question please mark the appropriate reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
Hi @SD_10134497
I wanted to follow up with you on your post. Upon further review, we have gone ahead and designated the post we feel successfully answered your question.
In the event that you disagree with the Solution Accepted, please let me know.
Thanks for using the PTC Community!
Abhi
