How to not lose data when adding stream entries rapidly
nmutter
It's an old question but "In PostgreSQL and H2, stream entries are keyed by the unique key entries of the timestamp and source." - https://support.ptc.com/help/thingworx/platform/r9/en/index.html#page/ThingWorx/Help/Composer/DataStorage/Streams.html
If you use another persistence provide you seem to be out of luck "The timestamp is a key field for streams. If you add an entry with the same timestamp, it will overwrite the previous timestamp (upsert). To avoid overwriting, specify milliseconds for the timestamp." - same source
Hey @slangley ,
yes, but only for "PostgreSQL and H2" referencing the docs. I did already mention it in the 'first' post. The thread was recreated as I added it to an older conversation.. But thank you for mentioning it again, better once to often.
I will close the thread with solution -> please check my initial post.
4 REPLIES 4
PaiChung
22-Sapphire I
(To:nmutter)
Also entries must be 3 miliseconds or more apart I believe, not sure if this is outdated knowledge from my brain ...
Just got an Support Article update stating
"The minimal timestamp unit to differentiate Stream and Value Stream entries is 1 millisecond" - https://www.ptc.com/en/support/article/CS340193?source=subscription
So it seems you can discard this information you had from your brain Space for new facts! Yeah
slangley
23-Emerald II
(To:nmutter)
Hi @nmutter.
It's worth mentioning that source is also considered for determining whether the update is unique.
--Sharon
Hey @slangley ,
