How to pass List of values from json object to SQL Query Service
snoor
I need to call a SQL Query service. Which Look-Likes :
select * from public.styleassociation where id in (?);
As input I am passing Json Object (Ex:  {  "values" :  [1,2,3]}
Can anyone help me, how to extract the values in "?" place.
snoor
(To:slangley)
Hello @slangley ,
I have found answers my self, the solution is
we need to iterate the List of values  and append each value as a single string with the single quotes and comas (EX: ‘ID1’,’ID2’). The same string we need to pass as a SQL service parameter and it working fine.
The same approached I have tried with the NUMBER parameter and its working.
Ex Code :
var res = "";
for(var i=0; i<tagsArr.length;i++){
var res1 = "\'" + tagsArr[i] + "\'" + ",";
res += res1;
var tagsVal = res.substr(0, res.length-1);
And in query param you need to pass  where tag_id IN (<<tagsVal>>) not in [[tagsVal]]
Best Regards,
Noor
3 REPLIES 3
rosharma
(To:snoor)
use JSON.parse() method to parse the values before passing it to query
slangley
23-Emerald II
(To:rosharma)
Hi @snoor.
If the solution provided by @rosharma answered your question, please mark it as the Accepted Solution for the benefit of others with the same question.
--Sharon
snoor
(To:slangley)
Hello @slangley ,
Ex Code :
var res = "";
res += res1;
Best Regards,
Noor
