How to pass a Query into the URL
tcoufal
Hi Guys,
since alert processing subsystem is not working correctly (case has been opend and bug reported), We are trying to workaround that a bit.
I have pretty standard REST call to my TW that looks like that:
http://localhost/Thingworx/Resources/AlertFunctions/Services/QueryAlertSummary?method=post&Accept=text/xml
Here goes my question.
How can I append a query?
For an example
var query = {
filters: {
type: "And",
filters: [
type: "GT",
fieldName: "Duration",
value: "0"
Is there any special formatting? How can simply put into the URL?
Thanks a lot
Tomas
PaiChung
22-Sapphire I
(To:tcoufal)
I notice you have the command line switch enabled, please remember that doing so, does put you at risk of CSRF
to pass the query, you should be able to pass it in with &query=yourqueryasJSONhere
tcoufal
(To:PaiChung)
Yep I have, but I am passing the appKey in URL as well and I am using the REST calls only on LAN. Which should be secure against any kind of interception. I will try that JSON format.
Thanks though.
