Hi
I am using a navigation control and through that I am opening one mashup, for that I want to pass some parameter values to the second mashup.
(viz PlantId and ProcessName) . How this can be achieved?
Regards
Pallavi
Hello Pallavi,
not sure how come you are logging in with Suraj's login, I recommend you get your personal login so you can get notification directly to your email.
You can pass these values using Mashup parameters, I recommend you go through our eLearning course that highlights the use of this, also I think our Navigation widget example might show it as well (sorry it has been a while since I checked the video accompanying the Nav. Widget)
