can we use JQuery for image animation in Thingworx or we can use flash or shockwave image in Thingworx?
rohitk
Is it possible to show shockwave or flash or similar type of images in Thingworx?
adam11
7-Bedrock
(To:rohitk)
Rohit,
ThingWorx's UI widgets are written using jQuery, so this is the approach I recommend for animating images. Section 9 of the Wiki contains information on creating widgets. Presumably, you could make some modifications to the existing Image widget to add animation.
Adam
adam11
7-Bedrock
(To:adam11)
To clarify, you can use the existing Image widget as the basis for an entirely new widget. You will want to copy the source files out $CATALINA_HOME/webapps/Thingworx/Common/thingworx/widgets, modify them and repackage them as an extension.
