How to ping Database server using javascript code in thingworx service ?
UY_9515947
6-Contributor
Okay got it, so in that case here is my 2 possible idea
1. Use other apps to communicate with cmd to ping the destination server, for example using node-red and ThingWorx can communicate with Node-RED via REST Call or other programming language would also works, I find it easier just using node-red. The apps can be deployed on the same server as ThingWorx
2. Validate after creating the Things
HI @UY_9515947
Usually, we ping it from the server that hosts ThingWorx. Can't you access the server?
UY_9515947
6-Contributor
(To:danmorin)
I can access both ThingWorx hosting and Database server.
Let me explain the case :
we are creating multiple MSSQL Things with JDBC Settings Parmeters as inputs.
so, wanted to Validate JDBC Settings Parmeters before creating the Things by pinging the database.
HI @UY_9515947,
Create a Thing with DataBase ThingTemplate, go to the Configuration Tab, and do the following configuration for MSSQL.
Shashi Preetham,
Email: psp316r@outlook.com,
Mobile: +91 8099838001.
