I am using google maps widget, I need to show number values per country on the map it self. eg. in japan 20000, china 15000 like that i have to show values in map without any additional mashups. For better understanding i uploaded screen shot for how data should be displayed in UI.
Hello @sabhz
You can use tool tips properties to show your data on the map as per the screenshot attached.
Let me know in case it does not resolve your query.
Om Dukiya
Hello @sabhz,
Have you tried following the example from https://developer.thingworx.com/en/resources/guides/google-map-widget-how
It has a sample implementation example.
Maybe this posts can help as well https://community.ptc.com/t5/ThingWorx-Developers/Displaying-the-country-names-on-google-map/td-p/53...
Hope it helps,
Yes i tried this but it's not working, I just need to show some string with number vales in each and every county.
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
