Hi @zhuwenxi.
Are you able to use another tool such as Postman to post on your REST service? If it still fails to post correctly, that would indicate there is a problem with the syntax. Another option is to change your TWX script to use PostTEXT, while keeping the rest of the content the same.
Please test these out and let us know the results.
--Sharon
Hi @zhuwenxi.
--Sharon
