How to query a datatable on both date and time basis.
SOLVED
Newbie
I have a use case where devices are sending data in JSON format to a broker server and from that broker server we are receiving data to data tables of thingworx through a service.
say we are receiving data for temperature, now I need to generate a time series graph that will display temperature data between the hours of 9 AM to 3 PM, also user will filter data by enter minimum date and maximum date.
So to display filtered data on graph I wrote the following service:
var query = {
  "filters": {
    "fieldName": "timestamp",
    "type": "BETWEEN",
    "from": minDate, // Input parameter for minimum date
    "to": maxDate // Input parameter for maximum date
var values = me.CreateValues();
var params = {
  maxItems: 500 /* NUMBER */,
  values: values /* INFOTABLE*/,
  query: query /* QUERY */,
  source: undefined /* STRING */,
  tags: undefined /* TAGS */
// result: INFOTABLE dataShape: "undefined"
var result = me.QueryDataTableEntries(params);
This service is filtering data on the basis of minimum and maximum dates passed by user as Input parameter. Now I am not getting how do I apply filter so that the service will display data only for hours between 9 AM to 1 PM for the input range of date passed by user.
for e.g
I want to display data from 1 september to 13 september only for hours 9 AM to 1 PM for temperature.
1 september and 13 september is passed by user as input parameter.
Looking forward for help.
Meenakshi
Re: How to query a datatable on both date and time basis.
You can filter the results after querying the data table.
var data = me.QueryDataTableEntries(params);
var params = {
  infoTableName : "InfoTable",
  dataShapeName : "yourdatashape" //change to your datashape name
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(yourdatashape)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
var tableLength = data.rows.length;
for (var x = 0; x < tableLength; x++) {
  var row = data.rows;
    var newEntry = new Object();
    if(row.timestamp.getHours() > 9 && row.timestamp.getHours() < 13){
        newEntry.desccription = row.desccription; //change to your required column name
        newEntry.count = row.count; //change to your required column name
        newEntry.name = row.name; //change to your required column name
  result.AddRow(newEntry);
10 REPLIES 10
Hi ,
As you say you have starttime and endtime datetimepicker widget  you should uncheck the initiallizecurrentdatetime checkbox, so before passing to this
query parameters
var query = {
  "filters": {
    "type": "BETWEEN",
You may need to use the dateAddhours snippet as because you may need to display records between 9AM & 1PM only
// dateValue:DATETIME
var dateValue = minDate, // Input parameter for minimum date
// dateAddHours(dateValue:DATETIME,amount:NUMBER):STRING
var calculatedDateValueStartValue = dateAddHours(dateValue, 9); // added 9 hours to the min date
Similarly
var dateValue1 = maxDate // Input parameter for maximum date
var calculatedDateValueEndValue = dateAddHours(dateValue1, 13); // added 13 hours to the max date
then you can do the usual thing
var query = {
  "filters": {
    "type": "BETWEEN",
    "from": calculatedDateValueStartValue , // Input parameter for minimum date
    "to": calculatedDateValueEndValue // Input parameter for maximum date
I have not tested this but i think you should give it a go ...!
Hope this helps..!
Hello Nilesh,
Thanks but it's not the solution of my problem.
I need to display data only from 9 AM to 1 PM  for all days ranging from 1 september(minDate) to 13 september(maxDate).
The solution you have posted is filtering my data as 2016-09-01 09:00:00 to 2016-09-13 13:00:00
It is displaying all instances of data from 2 september to 12 september whether it is between 9 AM to 1 PM or not.
For each day that falls in range I need to display data only for fix time interval, i.e. 9 AM to 1 PM.
var params = {
Just one appointment, if you have the server on a different TimeZone than the User, this code won't give the expected results, as it's executed on server TimeZone.
Then what will the best solution because I have server in different timezone than user.
I think about two ways to do this (but not very elegant).
1) With a "for" loop, create a query for each day, retrieve the data of each day and make a UNION of these infotable.
2) With a "for" loop, create a big query with OR and combine queries of each day.
It will also lead an issue of timezone. Users are in different timezone than the server.
Then you are out of luck, sorry, TW it's not well prepared for multi-timezone environments.
For this reason we had customized all Standard TW Time Related Widgets to support TimeZones, and also build a server side extension to work with Dates on TimeZones...
Best Luck.
Thanks!.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________
