Could anyone help us to query from info table based on condition?
We found query info table function but need to know query syntax please send us sample syntax
Example:
var params = {
t: result1 /* INFOTABLE */,
query: what to write here and how /* QUERY */
// result: INFOTABLE
var result = Resources["InfoTableFunctions"].Query(params);
We want to check where condition like where name ='anil' and id=1
Anil Kesana
var query =
"filters": {
"type": "OR",
"filters": [
"type": "EQ",
"fieldName": "Duration",
"value": "12"
"type": "EQ",
"value": "20"
look for "query parameter" in the documentation.
var query =
"filters": {
"type": "GT, LT, GE, LE, NE, EQ, LIKE, NOTLIKE",
"value": "12"
var params = {
query: query /* QUERY */
Hi Mnudel,
Thanks for your quick response , but I want to check multiple conditions not single value.
Could you explain that ?
var query =
"filters": {
"type": "EQ",
"value": "12" and/or "20" //like this I want to check will it possible please send syntax for the same
var params = {
Anil Kesana
var query =
"filters": {
"type": "OR",
"filters": [
"type": "EQ",
"value": "12"
"type": "EQ",
"value": "20"
Thank you so much Mundel got it
Anil Kesana
