How to query implementing things by identifier?
ckulak
Basically the title says it all. I have things with identifiers, which are different from their names. Is there a way to find a thing by its identifier? QueryImplementingThings with the query filter on "identifier" doesn't seem to work.
Constantine
8 REPLIES 8
ankigupta
(To:ckulak)
Constantine Kulak​,
QueryImplementingThings does not return identifier as one of the column.
You might have loop through each thing to find the corresponding identifier.
There may be a better way too.
That's what I'm currently doing, but it's ugly and inefficient.
qngo
(To:ckulak)
Hello, you can do that with QueryImplementingThingsWithData. The query filter will work.
ckulak
(To:qngo)
Did you try it? This query returns empty result for me, although I have a thing with identifier 12345:
ThingTemplates[“MyAssetTemplate”].QueryImplementingThingsWithData(
    { query: { "filters": { "fieldName": "identifier", "type": "EQ", "value": "12345" } } }
/ Constantine
qngo
(To:qngo)
I copied your code and change the ThingTemplate name and the fieldName. It works for me.
ckulak
(To:qngo)
The problem is specifically with the identifier, it's a standard field, just like name or description. This query works with other (custom) fields, it doesn't work specifically with identifiers.
qngo
(To:qngo)
Okey I see. It's weird. The query works though with other standard fields like "name" or "description".
ckulak
(To:qngo)
Yes, that's exactly the problem. I also opened a case with PTC Tech Support to see if they can help.
