Hi Team,
Suppose I want to read any csv file present in system repository and then parse it into a infotable then how would it be done using script?
Thanks in advance.
Hello @ranjank
May be you can use CSV parser extension for the same from our support portal. Please refer following help center guide which provide more detailed information about its services.
Let me know if it doesn't answer your query or you have further concern.
Om Dukiya
Hello @ranjank
Om Dukiya
Hi @ranjank.
If you feel your question has been answered, please mark the previous response as the Accepted Solution for the benefit of others with the same question.
--Sharon
