How to read thing property value using Thingworx Microserver
Velkumar
18-Opal
Hello all,
We are using Thingworx Microserver in raspberry pi, we have a requirement where we need to read Thing Property values using Thingworx Microserver .
Could any one help with this ?
VR
wcui
(To:Velkumar)
Can you try below coding from Luascript? More details in below article.
  • thingworx.server.invoke('ServiceName',nil,'ThingName')
https://www.ptc.com/en/support/article?n=CS297255
ckaminski
(To:Velkumar)
Greetings:
   Have you seen the Edge Microserver resources available at the following link?
    https://developer.thingworx.com/en/resources/guides/thingworx-raspberry-pi-quickstart
   If so, can you elaborate on the nature of the difficulties you are running into?
-Chris Kaminski
wcui
(To:Velkumar)
slangley
(To:wcui)
Hi @Velkumar.
If one of the previous responses allowed you to solve your issue, please mark the appropriate one as the Accepted Solution for the benefit of others on the community.
--Sharon
