How to reference data table, get specific column value, and use as entry into a separate infotable
ateed
For a current customer I am trying to implement a service that will record the Fault messages of the machine.
I've set up an infotable property on the asset that would house the recorded faults.
I've also set up a data table holding the fault code reference document that has a numerical code and string for each fault.
What I need to do, is when an Alert on the faulted PLC tag is triggered, to get the numerical code from a seperate PLC tag, reference that code in the data table, get the string equivalent, then add a row with all that information to my asset fault history infotable property.
I cannot get my javascript code to work, I'll paste below what I have currently, I am wondering now if it is easier to use data tables for both tables listed above or if this set up should work?
To clarify, I am using a configured Alert on the Faulted property (boolean) to trigger a subscription with the following code:
var PLCFaultCode = me.Current_Fault_Code;
var propertyString = "Fault_History_Table";
var query1 = {
"filters": {
"type": "EQ",
"fieldName": "FaultCode",
"value": PLCFaultCode
var params1 = {
t: Things["Mahle_GapGrind_FaultMessages_DataTable"] /* INFOTABLE */,
query: query1 /* QUERY */
// result: INFOTABLE
var result2 = Resources["InfoTableFunctions"].Query(params1);
me.AddInfoTableValueStreamEntry({
propertyName: propertyString /* STRING */,
value: result2 /* INFOTABLE */,
timestamp: undefined /* DATETIME */,
Any help greatly appreciated!
1 ACCEPTED SOLUTION
cmorfin
(To:ateed)
Hi @ateed
From the code you seem to be passing a dataTable as parameter t, that is then passed to Resources["InfoTableFunctions"].Query(params1);
This t parameter should be an infotable not a data table.
You can maybe test
var params1 = {
t: Things["Mahle_GapGrind_FaultMessages_DataTable"].QueryDataTableEntries({
maxItems: undefined /* NUMBER */,
query: undefined /* QUERY */,
values: undefined /* INFOTABLE */,
source: undefined /* STRING */,
tags: undefined /* TAGS */
}) /* INFOTABLE */,
instead, just to test that it goes further.
You can then check with service QueryInfoTablePropertyHistory if you see the update (I do)
Hope this helps
Christophe
cmorfin
(To:ateed)
Hi @ateed
You can maybe test
var params1 = {
}) /* INFOTABLE */,
Hope this helps
Christophe
ateed
(To:cmorfin)
Yes, so my problem was mixing data tables and infotables like you pointed out. I ended up changing the code quite a lot and it's working now, thanks for the help!
