Hi @eyli.
It sounds like you are installing the trial products, correct? If so, by running the Mfg Apps installer after running the ThingWorx installer, you most likely overwrote your previous installation.
If you are just evaluating the product for now, please be assured that when you purchase the product, you will not lose your projects as long as the installation procedure is followed. Note that once ThingWorx platform is installed, the procedure for installing Mfg Apps would be to simply import the needed extensions.
If you feel this response explains the issue you encountered, please mark it as the Accepted Solution for the benefit of others on the community.
Regards.
--Sharon
