How to remove selected row label from grid?
MB_9621099
I have used Grid widget with multi row selection on grid.
After doing so if we select multiple rows it does show how many rows we have selected on a grid as a selected rows label.
I wanted to hide it or turn it off but not getting any property to do so.
looking for any suggestion using which i can turn it off.
1 ACCEPTED SOLUTION
MB_9621099
(To:M4RC)
Thanks for the suggestion marc seems like css is the only solution on this in that case i will have to go with other approach but thanks to everyone for giving solutions.
13 REPLIES 13
Hi @MB_9621099
You can check it here
https://www.ptc.com/en/support/article/CS352537
Hope this helps you
Thanks!
MB_9621099
(To:danmorin)
Hi @danmorin
Before posting this issue i referred this post and now also i tried it but it doesn't get rid of that label.
so issue is still persisting.
Can you specify the ThingWorx version that you are using?
MB_9621099
(To:danmorin)
Thingworx 9.3.4
MB_9621099
(To:MB_9621099)
I tried this solution from that article :-
  • For ThingWorx 9.3
    • Select Base -> additional-label
    • Set a blank color or set Other:0px to font-size
when it didnt work also tried to modify other properties in base but it didnt worked either.
Hi @MB_9621099
I tried adding this on the custom CSS, and its working on my 9.3.4
.widget-ptcsgrid::part(selected-rows-label){
   display:none
could you try it again with this approach ?
Otherwise you can just use the Grid Advanced widget, by default it would not show selected row
MB_9621099
(To:danmorin)
Thing is that for our project we are not suppose to use custom css which is why i was looking for other solution apart from using custom css.
Then can you try to use Grid Advanced widget rather than Grid widget ?
MB_9621099
(To:danmorin)
Actually grid advanced is legacy widget and we are mostly using standard grid so it might be not used in our case but i will keep this suggestion in mind but if you have any solution around gird apart from css that would be great.
did this worked for you with 9.3.x version ?
  • For ThingWorx 9.3
It is still working on 9.3.3 version
MB_9621099
(To:danmorin)
ok because i tried same thing like shown in attached image but it still shows it.
M4RC
(To:MB_9621099)
the setting you are looking for is "selected rows-Label" which has only style options for padding top and bottom.
In this case I can recommend you to use CSS.
If you use a CustomClass, the code will only affect this grid. If you want it to affect all grids in your mashup, leave out the part (.myGridClass).
.myGridClass .widget-ptcsgrid::part(selected-rows-label) {
display: none;
Best regards
Marc
MB_9621099
(To:M4RC)
