Need to remove space of widget when its visibility set to false
Hi Aakash,
Could you please add some more description to your use case?. However , if you want to place one widget on top of another to utilize it's space, you can set a higher Z index for that widget. Basically ,a widget with higher Z index stays on top of a widget with lower Z index irrespective of it's visibility.
I dont want to overlap the widgets i want to use the widgets like menu with title and also avoid that blank space when hidden
