On right clicking column heading in grid, we can deselect certain columns. We expecting the selected columns to be save until it is changing manually in UUser Interface. But Once I reloaded the page, the grid columns are resetting back and displaying all columns.
How to save selected columns of Grid in UI.?
Hi @AP_10343008
Could you please tell Thingworx version and which grid (New Grid - 9.4, Grid, Advance Grid) used mashup?
Also if possible post some screenshot
/VR
Thingworx version is ThingWorx 9.1.0-b10877
Widget - gridadvanced
If I unchecked columns names in grid, on refreshing page the changes should remain same.
Hi @AP_10343008
Unfortunately, this cannot be achieved because you won't get selected/unselected columns as output in runtime.
But you can make use of configuration JSON to unhide/hide columns based on user/user selection.
For example :
In this example based on the selected type, grid columns will vary
You can achieve something like this
More about Grid Configuration JSON - Configuring the Grid using JSON Data (ptc.com)
/VR
/VR
Hi @AP_10343008.
With 9.3, PTC added a new grid widget with cache runtime changes, column order, column sizing, and column visibility. It would be a good idea for you to upgrade given the fact that the version you are running is no longer supported.
--Sharon
