How to send data to Google Map extension
Chanin
I use google map extension 3.1.7 in ThingWorx 9.3.2.
I having a problem using the tooltip, I can't send data to mashup.
in mashup  tooltip i add parameter configure mashup
Please suggestion me how to pass data to tooltip.
Thanks you.
Velkumar
(To:Chanin)
Hi @Chanin
I think the issue is with Google Map Widget version - 3.1.7. Even though in the changelog it is mentioned that issue got resolved but the issue still exists
When I checked with Google Map Widget - 3.1.1 I'm able to assign value to the tooltip mashup
Unfortunately, I don't have an older version extension if I found somewhere I will upload it here
/VR
8 REPLIES 8
Velkumar
(To:Chanin)
Hi @Chanin
Just select the field name from the dropdown so that it will pass value from data to the tooltip mashup
/VR
Chanin
(To:Velkumar)
Hi @Velkumar
i can select but i can't save
Velkumar
(To:Chanin)
Hi @Chanin
What do you mean by you cannot save ? Do you see any error/information message while saving ?
From your image, I can see Google Map Properties not showing Tooltip Mashup parameters name. Save the Tooltip mashup again and reselect the tooltip mashup in Google Map widget.
If those entities (Main Mashup, ToolTip Mashup, Thing, Datashape) are not confidential, you can put them here so I can test them in my environment
/VR
Chanin
(To:Velkumar)
@Velkumar
When i selected and save than refresh mashup editer dropdown back to not selected.
i have attached entities in this message.
Thanks you for you help.
Chanin.
Velkumar
(To:Chanin)
Hi @Chanin
/VR
Chanin
(To:Velkumar)
Hi @Velkumar ,
Thank you for your help.
Extension installed can found in \ThingworxStorage\extensions, if it possibly zip and upload here please.
Thanks you.
Chanin
Chanin
(To:Velkumar)
Hi @Velkumar ,
I got Google Map Widget - 3.1.1 already.
Thanks for your help
Chanin
Velkumar
(To:Chanin)
Hi @Chanin
Great. If possible could you please upload it here
/VR
