How to send data to Google Map extension
  • April 26, 2023
  • 4168 views
I use google map extension 3.1.7 in ThingWorx 9.3.2.
I having a problem using the tooltip, I can't send data to mashup.
in mashup  tooltip i add parameter configure mashup
Please suggestion me how to pass data to tooltip.
Thanks you.
Best answer by Velkumar
Hi @Chanin
I think the issue is with Google Map Widget version - 3.1.7. Even though in the changelog it is mentioned that issue got resolved but the issue still exists
When I checked with Google Map Widget - 3.1.1 I'm able to assign value to the tooltip mashup
Unfortunately, I don't have an older version extension if I found somewhere I will upload it here
/VR
Hi @Chanin
Just select the field name from the dropdown so that it will pass value from data to the tooltip mashup
/VR
Chanin13-AquamarineAuthor
Hi @Velkumar
i can select but i can't save
Velkumar19-TanzaniteAnswer
Hi @Chanin
/VR
