Hi all,
I'm newbie, I have a platform to send data in the syntax [CS*YYYYYYYYYY*LEN*WAD,Language,location data].
What protocol do I need to TW to get the data.
Hello @DN_9687801,
Have you seen the following posts on community:
https://community.ptc.com/t5/IoT-Tech-Tips/Protocol-Adapter-Toolkit-PAT-overview/td-p/534599
Hope it helps,
Hello @DN_9687801
As I can check the format you mentioned can be sent in a variety of protocols, MQTT, REST, JMS, AMQP, pure TCP, and the list can continue. But the main question raised here is what protocol does your system support.
Thank for answer
Currently my platform is communicating with the server via the GTP protocol. Does TW support it?
