How to set image in media entity dynamically?
done11
i am trying to set the image in media entity dynamically, using following code snippet :
var params = {
  url: path /* STRING */,
// result: IMAGE
var result = Resources["ContentLoaderFunctions"].LoadImage(params);
getting below exception:
clientprotocolexception null
Any new suggestion for doing it?
Thanks in advance!
ttielebein
(To:done11)
What are you passing in as the path?
posipova
20-Turquoise
(To:done11)
Assuming you already have a media entity named "TestMedia", here's an example of how to make it work via service. You may input a url and plug it in, you may also create an entity using a snippet, but here's the general idea and a hardcoded example that works. Let me know if you need any further details.
var params = {
  url:  'https://pbs.twimg.com/profile_images/447374371917922304/P4BzupWu.jpeg' /* STRING */,
// result: IMAGE
var image = Resources["ContentLoaderFunctions"].LoadImage(params);
var params = {
  name: 'TestMedia'/* STRING */,
  content: image
// no return
Resources["EntityServices"].UpdateMediaEntity(params);
