How to set multiple marker in google Map in Mashup ?
mpatel-21
Hello Expert,
I am working on one application whose tracking the location. I was stuck when assign a marker like this is  Home and this is Office in Thingworx Google Map.
Please give me answer for how can i assign marker i was try many things but does not reflect on Map.@
Thanks ,
Mayank
mpatel-21
(To:PaiChung)
Thanks Chung,
I got my answer : Now it's solve my problem.
var params = {
    infoTableName : "InfoTable",
    dataShapeName : "Datasahpe"
// CreateInfoTableFromDataShape(infoTableName:STRING("InfoTable"), dataShapeName:STRING):INFOTABLE(Datasahpe)
var result = Resources["InfoTableFunctions"].CreateInfoTableFromDataShape(params);
// location:LOCATION
var location = new Object();
location.latitude = 23.452;
location.longitude = 72.124;
location.elevation = 0;
location.units = "WGS84";
result.AddRow({location:location})
//location:LOCATION2
var location2 = new Object();
location2.latitude = 23.123;
location2.longitude = 72.456
location2.elevation = 0;
location2.units = "WGS84";
result.AddRow({location:location2});
Mayank
PaiChung
22-Sapphire I
(To:mpatel-21)
Assign a table of information (infotable) with locations
one row would be Office and its location
one row would be home and its location
etc.
You can drag that directly onto the Google map, make sure you assign the proper field to the location property afterwards.
mpatel-21
(To:PaiChung)
Thanks Chung,
var params = {
Mayank
