How to set property when click different/multiple buttons?
xcheung
Hi all,
I want to know how to trigger set property after click on different buttons:
If we have 4 buttons: a, b, c, d, there are 15 options to choose (a,b,c,d,ab,ac,ad,bc,bd,cd,abc,abd,acd,bcd,abcd) and the options will return different values.
Is it possible to set one value based on the different buttons selected?
posipova
20-Turquoise
(To:xcheung)
If I'm understanding your use case correctly, you would need to create a service that tracks the buttons selected and then assigns a value based on that. You may try looking into boolean flags. assigning it with each button click and then comparing the combination at the end.
Hi Cheung, Why don't you use the Checkbox for ABCD and then a button to upload the answer?
