How to set the description values of a thing?
yingziDing
I wanted to reset the value of description while one property of the thing changed. I used subscription, and set the  DataChange to execute the script.
But the Application log showed that the property description is read-only. Is there any way that I can do the job?
7 REPLIES 7
dmoon
(To:yingziDing)
To clarify your question, did you make a property named "description"? And you added a subscription for a datachange event of it, right?
If so, can you share your setting for the property and a script for subscription?
Daniel
yingziDing
(To:dmoon)
Hi Daniel,
The "description" I talk about is thing's description. When we create a thing, we should input name, description, template, thingshape for the thing.
I want to reset the thing's description, when a property named "nickname " changes. I used a subscription to do that.  For example, when the value of "nickname" is set to "My First Device ", the thing's description is set to "My First Device".
yingziDing
(To:yingziDing)
The Application log return.
Hi Mr. Ding,
You can use SetDescription service the set device descriptions.
Lily.
yingziDing
(To:liliu)
Hi Miss Liu,
Uh.. If I do as your method, I can finish the job. If I can't do it using a subscription at last, I will use this method.
Thanks for your help.
yingziDing
(To:liliu)
Hi Miss Liu,
I understand what you mean. It works.
Hi Mr. Ding,
Great, any concern, just let me know.
Lily
