Hello everyone
I can't display the starting position and the end position when using the route function of the map. How do I set it?
Hello Mr.Liang,
It seems that you can draw the line using the Route in Map, so you might be asking for the Start and End location marker.
If you are binding data to Data in Map, and configure it like this
But the Markers could not show in the Route and Region.
And if you are using the same set of configuration: ShowPath, ShowStartMarker, ShowEndMarker, you can still get what you want.
if you bring in the data as Route data you can have have a start and end marker
Hello Mr.Liang,
hi Ryan Yuan
I've tried to set these three properties before,It didn't work out!
Is there any requirement for the data?
4 properties from the ShowMarkers to ShowEndMarker only respond to Data input,
Only ShowRoute responds to Route input field in the Map widget. And you should select a input for Location field
Hi Ryan,
Is there any way to display Markers for a Route? Only End point/Latest location displays marker and rest as a Blue line.
Tarun
Hi Tarun,
The RouteData don't support Markers in between the START and the END, while Data do
Binding to Data then all the Markers can be shown, and ShowPath draw the lines between the Markers
Check out the upcoming Expert Session: Understanding ThingWorx Navigate Licensing in Community "Customer Events" section.
