I am creating a bar chart with 7 Legends and legends are showing in multiple columns.
Is is possible to show all legends in one row.
Requirement-
Thanks in advance.
In my version, I don't see any way to intervene, neither in the widget nor in the style themes.
If no one else can name a possibility, the question is whether you have to use the function of the legend,
then you may have to live with the look for the time being until it is adjusted.
If not, you could hide the legend and create your own underneath the chart.
possibly as a separate mashup and integrate this with a contained mashup.
You can read the coloring of the lines from the style theme used for the page unter charts.
Internally it creates Grid to show legends on Chart bar.
Hi @Subodh_Sharma ,
I wanted to follow up with you on your post to see if your question has been answered.
If so, please mark the appropriate reply as the Accepted Solution for the benefit of other members who may have the same question.
If not, our industry expert is also reviewing the replies and may accept one of them as solution on your behalf.
Of course, if you have more to share on your issue, please let the Community know.
Wcui
