How to show default data in any widget when filter is not applied on list widget
Susmitha
Can any one suggest on how to show the default data in widget when filter is not applied on List widget.
Here in my Mashup , Default it is showing no data in widgets . When it is selected on any item in list it is showing correctly. But I want to show all data default .
Susmitha.
For the List widget you have which receives data from a service, it has a checkbox named AutoSelectFirstRow, it can focus on data in first row in infotable on mashup loaded;
If you're binding data source to a service, apply Service Trigger on Mashup Loaded, together with previous step you  can show data on the widgets.
Susmitha
(To:zyuan1)
We have enabled the AutoSelectFirstRow . We have written the service manually regarding what items should be there in list. So we have given ALL option in the list in order to get the default mashup . But it is showing empty page when loading ALL as first option . we want to get the default mashup first and based on selection in list the widgets should change.
What is the ALL option in the list you're referring to?
