Hello! I am new to ThingWorx and have created a custom widget. I want to hide/show that widget depending on how an Expression evaluates. I have the widget imported and the expression tested, but i do not know how to hide/show the custom widget...could someone give me advice? Thanks in advance
I do not think so, but i can get it...
However, i figured it out! I used the Expression widget to compare a property field in one of my widgets. Then I had to change the output type from String to Boolean, and then drag that output on to my custom widget. It prompts me to bind with a property, and I chose Visibility...worked like a charm.
Thanks for the help Pai!
Since each widget supports that feature, I would look at the code one of the existing widgets uses.
On the server go to tomcat/webapps/thingworx/common/thingworx/widgets
Hello Pai,
Thank you for the response! I am not sure how to view what you are suggesting...
If I go to x.xx.xxx.xxx/tomcat/webapps/thingworx/common/thingworx/widgets, I get a 404 error. I have tried a few variations of teh address, but nothing seems to work. Any ideas?
Thanks again for your help!
You'd have to be on the actual server itself to get to that information. Do you have actual access to the server.
