How to show "No Data" like this in advanced grid widget?
AP_9587236
How to show "No Data" like this in advanced grid widget? Kindly refer the attached image.
M4RC
(To:AP_9587236)
before your service returns an empty value, you can add a fixed row, which contains a value like "Nothing found".
Best regards
Marc
6 REPLIES 6
Very simple. I use a contained mashup (one which has that message in the center), that I switch to. I do not use the Grid itself for this situation.
when there is data for corresponding search, the grid should show all the rows. When there is no data for the corresponding search, we should show no data. If anyone have any idea let me know.
M4RC
(To:AP_9587236)
Best regards
Marc
VladimirRosu
(To:M4RC)
Hi Marc, that is indeed a quick solution, but I found from time to time a contained mashup you switch to is more flexible (allows bigger font size, proper centering) and that's why I go with that option. However, it's correct to say adding a row it's the fastest way to achieve this usecase.
Thank you @VladimirRosu @M4RC
GuillaumeL
(To:AP_9587236)
This is a bit aside so it will not answer your question but be aware that this behaviour is OOTB with the new grid in 9.3
