How to shrink the top dynamic bar
Alexey_Arkhipov
Good day!
Please tell me how to reduce the top dynamic panel?
It is necessary that the split is just below the drop-down list so that after selecting a line, you can hide the filter
I figured it out, it was necessary to set the "MinSizeWhenExpanded" parameter to 95%
3 REPLIES 3
If it is just a fixed height you need, you can set it to static.
Else you need to adjust the grow shrink ratios
I need a static height for the top dynamic bar. For this panel, if you select "static" in the "Layout" menu, you cannot set the desired height. In the parameters of the panel, I also did not find the parameter responsible for the height. Can you tell me where exactly this can be corrected?
