How to transfer file from thingWorx to remote device using EMS
ghaly
Hi i need to know how to transfer file from thingWorx platform to Remote device using EMS ?
paic
(To:ghaly)
If you have access to the PTC elearning materials, I recommend you search for File Transfer there should be a whole chapter on it.
the basics would be.
1. EMS enabled for file Transfer with a Repository defined
2. A matching RemoteThingWithFileTransfer in the Model
3. A File Repository in the Model
4. use the FileTransferSubsystem Copy service.
gseq
7-Bedrock
(To:paic)
I'm figuring out how to do this with the SteamSensor exampleWithFileTransfer. Are there example mashups?
Also, on the learning materials.. I only see the "How to use a File Upload Widget" video.
