Hello Everyone,
i would like to create a navbar for my master mashup. I can see my mashups in the menu widget, but if click on a mashup button in the menu i simply navigate to the mashup, leaving the master. It seems that is working as a simple link. Could you please help me?
Thanks for your reply,
Every widget is linked to the related master using the "master" property. But it's seems that i've missing something
Here's my steps:
- created Mashups
- created Master with a "contained mashup" widget and menu widget
- created a menu object with all the mashups i need
- linked this menu object to the menu widget
- the outgoing property of the menu widget is linked ( as input ) to the mashup property in the contained-mashup widget
- Every widget is correctly configured with the same master
am i missing something?
best regards
PFA entities for your reference. I'm able to navigate between 2 mashups with same master.
