How to use Functions to enable visibility of a widget
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Notify Moderator
Does anyone know how to set up a function perhaps an expression to send the "true" boolean to the Visible property of a widget or container in a mashup?
My mashup displays a grid with data and with a button below the grid to allow the user to export/download a CSV of the data displayed. I would like this button to become visible only when the data has finished loading in the grid.
TIA
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @mariaSutton
Create an expression which always sends Output as True
Output = true
Disable Auto Evaluate and Change Date Change Type to Always
Whenever grid data service completed, you evaluate the expression
And map expression output to Button Visibility.
There is one more suggestion instead using expression you can use custom service to validate infotable data.
You can create custom service to validate infotable data size
let datalength = infotableinput.length;
let result = datalength > 0 ? true : false; // To set button visibility
And map service output to button visibility.
In this approach, button will be invisible if there are no data returns from the service
/VR
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
- Notify Moderator
Hi @mariaSutton
Output = true
/VR
