I tried to use Polymer web components(Polymer.html) library file in thingworx in creating Custom widget.
I have placed the polymer.html file under " ui/Widgetname " and mapped it in the runtime.js file.
When I tried to run add this custom widget in the Mashup and runs , it throwing an error like " Polymer is Undefined".
Kindly help me in resolving this issue.
Hello, Avinash G.
While not having any specific experience with Polymer, you should be able to use any external libraries you want in a custom extension, so long as you include the necessary libraries in the build path. You'll have to look up the syntax to use for this purpose based on how you are developing the widget.
-- Craig A.
