Suppose a user is logged in a system using Windows authentication, now when that user opens thingworx we want that his windows authentication should be taken as his login for thingworx(No separate login for thingworx)
Hello, you should just need to add a DirectoryService configured to point to your Windows Server. I imagine it would look something like this the LDAP solution described in KCS CS221840 Hope this helps!
Hi Tori,
I went throught the document for LDAP. So in case of windows authentication do we have add the username and password fields in the LDAP directory XML file which is imported?
Hi All,
Suppose a user is logged into a system using Windows authentication, how to read user id and other details (domain, user name, etc) from Windows machine and send these details to thingworx configured ldap for authentication
