How to use the ThingWatcher
cdai-3
1-Newbie
Dear Sir/Madam,
I install the ThingAnalytics and ThingWatcher according to the installation guide. And I upload the training-service.tar, model-service.tar and install them on docker. And after that, how to use the ThingWatcher?
Where can I get some resources, videos or something else to use the thingwatcher? How can I write the ThingWatcher?
I want to have an example to study.
Looking forward to your reply.
Bests,
Calla
7 REPLIES 7
ttielebein
(To:cdai-3)
There is a section on "Using ThingWatcher" in this guide, have you already seen this?
Hope this helps!
I installed the docker, the Model Microservice and Training Microservice according to the ThingWatcher Development Guide.pdf. And I can get the following results.
Then I write a thingwathcertest1.java according to the guide.pdf, but I don't know what can i do after this? Would you mind to give me an example?
or some more detail guide which tell me how to use the ThingWatcher?
Thanks a lot.
nsampat
(To:cdai-3)
Calla,
Have you reviewed this Blog post presented by one of our Principle Tech Support Engineers?
Sample Java utility to validate ThingWatcher 52.2 installation
Or are you asking for a use case on how to use ThingWatcher?
Neel
cdai-3
1-Newbie
(To:nsampat)
yeah, I read it. Thank you. "Sample Java utility to validate ThingWatcher 52.2 installation" gives me a lot of help.
cdai-3
1-Newbie
(To:nsampat)
Hi Neel,
I have another qustion. What's the function of HostDBFile_ModelMicroService, HostModelDestion, HostSharedFile_ModelMicroService? I just know these forder are amount to docker, and to transfer files. But I don't know which file will be transfer. Or which file will be stored in the above folder. Looking forward to your reply.
Bests,
Calla
fseheutderonchi
(To:ttielebein)
I didn't find anything about the model microservice.
My understanding is that the model service is supposed to help deploying a model trained once for a device to other training microservice (eventually for other devices). But I see nowhere in the documentation, how to do so.
Would you have leads on that please?
Thanks in advance for your help.
Hi Francois Xavier
The training microservice is the brain that does the computation and create the prediction model.
Once created, this model needs to be stored somewhere.
There are different options for that, but a convenient one is to store the model in the model microservice.
This then allows to restart a ThingWatcher from a previously created model directly in monitoring mode without going through calibrating mode.
There is a sample on how to start a ThingWatcher in monitoring mode in the Help Center.
Hope this help
Kind regards
Christophe
