How to write superscript text directly.
Amethyst
I want to write superscript text m/s2 as m/s2
Tried using html tag <sup> but dint work out.
Can we have any option to directly write in the field.
Sunay
Re: How to write superscript text directly.
Hi @sbt  could you specify where exactly you trying to insert this value? Is it part of an entity's property?
Hello Sushanth,
I was trying to put the value to the "y-axis title" of the bar graph and also to the "TextIfNoValue" of the valuedisplay widget.
Sunay
Sorry for not getting back quickly, but i haven't yet found a way for this. Will keep checking and come back if i see something that works. May be in the meantime someone else here have more idea
Thanks.
Thats fine, not a problem.
But hope we get some reply from the forum :-).
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum!
