I want to write superscript text m/s2 as m
Tried using html tag <sup> but dint work out.
Can we have any option to directly write in the field.
Sunay
Hi @sbt could you specify where exactly you trying to insert this value? Is it part of an entity's property?
Hello Sushanth,
I was trying to put the value to the "y-axis title" of the bar graph and also to the "TextIfNoValue" of the valuedisplay widget.
Sunay
Thanks.
Thats fine, not a problem.
But hope we get some reply from the forum :-).
