How top automate model creation?
user539
8-Gravel
I created a model in Thingworx Analytic Builder.Now I should automate retraining the model with additional data without manual process and generate a PMML file.Is there any way ?
It will be helpful if explained in detail.
cmorfin
(To:user539)
Hi @user539
Certainly the easiest would be to use the Retrain menu in ThingWorx Analytics Builder. This obviously implies manual interaction.
If you want to automate it you will need to code some services that call
AnalyticsServer_DataThing.AppendDataset to add new data
AnalyticsServer_TrainingThing.CreateJob to create a new model with this append dataset
AnalyticsServer_TrainingThing.RetrieveModel to retrieve the PMML file.
The ThignWorx Analytics API  help can be found at https://support.ptc.com/help/thingworx_hc/thingworx_analytics_8/thingworx_analytics_8/baggage/index.html
Hope this helps
Kind regards
Christophe
cmorfin
(To:user539)
Hi @user539
Hope this helps
Kind regards
Christophe
CRArko
(To:user539)
Hello, user539.
Did the advice provided by Christophe help you through this? If so, please mark his response as 'solution accepted,' so others with the same question will be better able to search out the answer.
If it didn't help you enough, let us know and we'll keep digging into this.
Thank you,
-- Craig A.
