I am facing problem in providing color to text in label widget using CSS code .i WILL PROVIDE THE CODE BELOW :
.simple-label {
width: auto;
height: auto;
display: flex;
color: red;
font-weight: 400;
line-height: 14px;
Why don't you use Style property of the widget instead? If you reuse your Style objects consistently, it will be more flexible and easier to maintain in the long-run.
/ Constantine
I want to try it using CSS code.Please give me some suggestions
This will work (change CSS class in label widget):
.label-text {
width: auto;
height: auto;
display: flex;
color: red;
font-weight: 400;
line-height: 14px;
Best regards,
Raluca Edu
No .it did not work if i change the css class too
In 8.4.4 worked, what version are you using?
8.4 version
Please attach xml export of simple mashup to look into.
Raluca Edu
@sanjanabalaji In your original example, add ".label-text" to the CSS selector like that:
.simple-label .label-text { width: auto; height: auto; display: flex; color: red; font-weight: 400; line-height: 14px; }
The custom CSS class is applied to the DIV, which encloses the SPAN with "label-text" (not to the SPAN itself), so you need to specify an explicit CSS selector to override "label-text" parameters (dark-gray color, bold, etc.)
/ Constantine
