I am looking to create a function to read a local file content into a variable in Thingworx (not om the edge). Is that possible, and how? I tryed regular javascript read file functions do far with ho luck eventually just in the composer first and then in a machup on my local PC in linux or windows.
The idea is to load stuff out of the file and then use that data for other purposes, such as config changes.
Easiest way would be to use the File Repositories and use the Loader functions associated with the File Repository.
Thingworx can easily parse JSON or XML content and with an extension, CSV content
Hi Pai,
How to execute the service and if I need to write values within the file how to read that.
