I am not able to import CSS in Thingworx mashup
AM_10639709
Hello
I am trying to import Custom CSS in thingowrx mashup design but it has not been applied . I am using @import to do so. Is there anything I am missing here. The same was working with my older thingworx versions?
Any help would be appreciated
Hello @AM_10639709
I have checked that this issue is corrected in ThingWorx version 9.4.1. You can refer the attached article:
https://www.ptc.com/en/support/article/CS400746
Regards
Bhawna
3 REPLIES 3
Hello @AM_10639709 ,
Could you pls share the version of your ThingWorx?
Regards
Bhawna
Hello @bchaudhary
Thanks for the quick response , The twx version is 9.4.0. Does it make any difference with different twx version?
Hello @AM_10639709
Regards
Bhawna
