I got an error message and how to fix this?
jlee1
Dear,
I have an error to delete extension.
Extension Package deletion failed: Unable to Invoke Service DeleteExtensionPackage on PlatformSubsystem : Cannot delete ExtensionPackage [Neuron_Extension] because the following Extension Entities are still in use: [entity: NeuronFilterDetail, used-by: TW.Discover.NeuronGroup Neuron.NeuronGroup ][entity: NeuronClustersFeature, used-by: Neuron.NeuronClustersResult Neuron.ClientToolkitTemplate ][entity: NeuronPredictionsLearner, used-by: Neuron.ScoringJobResult ][entity: NeuronFeatures, used-by: TW.Discover.NeuronFeatures ][entity: NeuronAll,
And so when I try to update extension, I also got the below.
Error importing: error: Not Acceptable - [package: neuron-extension-3.0rc3, error: Cannot update existing ExtensionPackage [Neuron_Extension] because the updated ExtensionPackage is trying to remove the following Entities that are still in use: [entity: NeuronSignalsThing, used-by: NeuronSignals ][entity: NeuronDatasetThing, used-by: NeuronDataset ]]
How to resolve this issue?
4 REPLIES 4
Aanjan
(To:jlee1)
Can you try restarting your Server/ Tomcat and then deleting the extension?
jlee1
(To:Aanjan)
I did but I could get same results.
Aanjan
(To:jlee1)
I'm not sure if you tried this already, but can you try deleting the listed entities manually?
emadar
(To:jlee1)
Hi, I have the exact same error, even though nothing is open in thingworx, and moreover i've already done a restart of the server... How can I fix that? (It gives me errors on entities that I did not even open)
