I create thing using snippet
n,T is Input parameter
so i create test1
and i want set this property
but Thing was created by snippet couldn't change properties
i input some test message in property Test1 Value
and click Set But
anything change...
but i create Thing using Create Thing in more button
it was changed properties
why i create thing with snippet can't change properties?
how i can make change properties with create thing using snippet?
Hi Sehnho Cha,
Could you do again following below from scratch:
1. in an existing Thing, create a new Service and author it like:
var params = {
name: name /* STRING */,
description: undefined /* STRING */,
thingTemplateName: TemplateName /* THINGTEMPLATENAME */,
tags: undefined /* TAGS */
// no return
Resources["EntityServices"].CreateThing(params);
Things[name].EnableThing();
Things[name].RestartThing();
name, TemplateName is input parameter
2.Go to the thing created by snippet, and add a new property manually, and then set a value for it and see if property is changed.
3. If property is still not changed, please check your new created thing's General Information, and see if the Active is checked.
Br,
Anna
Dear Seonho Cha,
By default after you programmically create a Thing, it's still inactive. You need Enable it with adding this code in your script:
Things[YOURTHINGNAME].EnableThing();
and try it again.
Br,
Anna
Thanks Anna An
i try "Things[YOURTHINGNAME].EnableThing();" this script in my script
but doesn't changed...
this is make with create Thing in more button in Template
this thing was Depedns On display
and this is create thing with snippet
and any depends on don't display
is this issue make problem?
how can fix it?
Hi Sehnho Cha,
var params = {
// no return
Br,
Anna
Thanks Anna An
i check that
and activity is not checked
how i check when i create thing with snippet?
hI Seonho Cha,
If you called EnableThing() properly, Thing should be active.
If you like, please join my webex room to have a look. https://ptc.webex.com/join/lan
my room number is: 800 022 691
Br,
Anna
thanks i did it! really thanks!
